My DAV-IS10 will no longer auto power on when my SONY Bravia TV is powered on
profile.country.en_GB.title
m1bds1
Visitor
The two are interlinked by an HDMI cable.  I have tried resetting the HDMI settings on the TV but this does not rectify the problem.  At present I have to manually power on the home cinema system else the TV sound will default to using the TV speakers. Can this fault be rectified by changing a setting somewhere or is there a hardware fault with either the TV or DAV-IS10?
Tags (2)
1 REPLY 1
specialist-convergence
Visitor
Hi could you please advise on the model of the TV and if HDMI control is enabled on both products
