Hi Sony,
While/when i'm on call with a person, i'm unable to persist the phone number from him on the dial pad text box.(so that i can directly call second caller from the dial pad once i end the first call)
I'm able to dial the number in the Dial pad Text Box when we're on call .
But once i end the call, the number is flushing.
Please address to this issue
Solved! Go to Solution.
Hi,
Instead of opening the dialer in the call view you can press the home button when in a call. Open the contact app and select the dialer tab, this text box will not be removed when you end the call.
