- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Unfortunately it sound like some moisture may have got into the phone and is now starting to affect the circuits. This is not covered within the warranty and I'm afraid it can't be repaired at any authorized repair center.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
for time being what I must have to do...rather I should use it or let have switched off for some day or two?
Or have some hair dryer air to dry as I have read it somewhere?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The best thing you can do is to leave it dissembled (removing back cover and battery) to dry for a long period of time, but that's unfortunately no promise that it will work properly again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ya thanks...I will surely accept it as final way to get it solved...
by the way that moisture will get removed or I need to change the disply and touch panel...?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi.
If it's not working, without warranty and you have nothing to loose, you could try to disassamble it and try to dry and clean up as much as possible inside the device. Also disconnect and reconnect as many (very small!) connectors as possible.
Youtube video how to disassamble it:
http://www.youtube.com/watch?v=q57SNwEvl0s
If this is advicable or not of course depends how skilled you are with electronics and what tools you have.
I have some experience and have repaired a number of mobile phones also by buying spare parts from internet shops.
Obviously, Sony will not recommend this...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sure will try............
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello yuvi1027! Pls tell me your current xperia L condition,whether the issue is resolved or not ? since i am facing the same problem with my xperia L
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
