4.3 update notification disappeared!!!
SOLVED
Chaithuu
Visitor
Hello fellow Xperians...I'm from Hyderabad.I have received the JB 4.3 update on 7th May..I tried to download it through mobile network..It went smoothly upto 65% and then the downloading disappeared..It was back to notification(New system update available)...So I decided not to waste any more mobile data and update it through wifi..Today morning,the notification is gone..Did anyone face this issue??
1 ACCEPTED SOLUTION
Accepted Solutions
Chaithuu
Visitor
Don't know when it started but I received the 4.3 update via PC Companion today..The update went smoothly..Still nothing through phone...No bugs so far..Hope everyone gets the update too..
43 REPLIES 43
shivang
Visitor
I am having the same problem. Update of andriod 4.3 automatically disappeared today morning. Don't know what is going on.
Please provide solution for same.
Tags (1)
Chaithuu
Visitor
Shivang,,When did you receive the update?
Alexander1
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Strange, have you tried to open the update center application to search for new software update?
If that says you already have the latest software, try to update using a PC:
http://www.sonymobile.com/update
Chaithuu
Visitor
Yeah,I tried after doing a factory reset.Got update for update centre,but no JB update..Pc companion says My phone has the latest software update..I tried Sony Update Service too..But no result..I heard that the update for Xperia M is only available through OTA..Is that true?
samkkr
Visitor
yes chaithuu thats correct, just got the update myself yesterday, its an ota update, goto update center refresh the app it will give an update for the app first then download and install the update of the app and then goto update center again it will give u an update for jb 4.3 and then follow the same thing and install the update.. my update was smooth, the update is arnd 367mb only for ota.. cheers.. let us know more on it
Chaithuu
Visitor
samkkr
Visitor
i woud also suggest to clear data of update center if same problem persists then try again.. and yes am using Vodafone
Alexander1
Champion
Could you please send me a PM with your IMEI number and customization version.
To see your IMEI number press *#06#.
To see your active customization number > press *#*#7378423#*#* > service info > software info > active customization.
Chaithuu
Visitor
Thanks for the reply Samkrr....I received the app,then the update for JB 2 days ago...But today,,there's no notification of the update...
