How to downgrade to 4.3?
SOLVED
SZLevente
Visitor
Hi,
I updated to 4.4.2, but i don't like holo ui, new system ui, and i lost write acces to sdcard. (last is Google's error, i know)
How can i downgrade to 4.3? It is possible to downgrade via PC Companion?
21 REPLIES 21
Thommo
You can use a generic .ftf firmware file - The only difference will be the pre-installed T-mobile features/apps will not be installed
Just make sure that if you have a D2303 version phone to use a D2303 firmware file
Thommo
I uploaded the D2303 4.3 generic UK firmware to XDA if you need it
SZLevente
Visitor
Hm ok, so i can use D2303_18.0.C.1.13_CE.ftf
Yes, i have D2303
But now i see, i can't download this Face_with_open_Mouth
https://drive.google.com/file/d/0B_d8uWGbkaetRnhpVEJyc0cwaHM/edit
Unfortunately, the file is currently not view or download.
Recently too many users have viewed or downloaded this file. Please try again later to access the file. If the file you want to achieve particularly large or too shared with many people in it, view or download the file may take up to 24 hours. After 24 hours, if you can not access a file, contact your domain administrator.
(Google translate cause i'm from Hungary)
Can you give me the tft working link?
profile.country.RO.title
_alexdon_
See here.
alexdon
Thommo
Here is the UK Generic Firmware for the D2303 - Version 4.3 18.0.C.1.13 - Customization number 1281-1574_R5A
https://mega.co.nz/#!04xShZLT!pKgHt0...UwjGcHcytDnZgQ
SZLevente
Visitor
While i install drivers, i can't find M2
error
Why?
Thommo
Install Pc Companion
SZLevente
Visitor
Already installed.
Thommo
So what exactly is the missing driver - The driver your image refers to is not from Sony - This is something made via members on XDA
SZLevente
Visitor
And what should i do? Install only flashmode and fastboot driver then try to flash the tft?
I've never flashed before. Pls help
