I had a 4% of the battery and the phone suddenly switched off and no longer included.
There was a red battery at first (the phone was all the time under the battery charger)
After it flashed 3 times the stop light and the phone stopped to react neither nothing. All the time he is charging and NOTHING.
bye my new xperia?
Solved! Go to Solution.
The red battery icon appears on the display now? Could you try charging the phone for 1-2 hours again and then try to power it on?
Connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2 - 3 hours > repair the phone with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
still not work
Hi @xszymi1337,
Does the device react if you press the volume up key and the power key together at the same time for 5-10 seconds?
no. now i have red battery
what some a red battery and lightning are for five seconds and they are restarting
@edit
now click power; 3x red led
in the morning for me he boot in for 5 seconds
i connect phone to pc for 4-5 hours and he is working now
thank you man
