When I use a USB cable to connect it, nothing happens. PC Companion stops working and I can't open it. What should I do?
Solved! Go to Solution.
No. Now it says there are no drivers, but i have PC Companion, and I can't find them on the Internet
I think it might be related to your operating system.What windows are you using?
Windows 7 Ultimate (64-bit). But I don't think it's my laptops fault, my sister has a Xperia J and it connects every time
I'll try and I'll let you know what happened in a few minutes.
Sure.
It's working with my dads computer (Windows XP, 32 bit), Thanks, Gandalf
I'll give you Kudos to everything
There might have been some incompatibilty issues or simply driver problems with your Windows 7.Probably a windows reinstall could have helped.But this sounds good.You do not need to give me any kudos,it is great that we found kind of a solution.
