Hi,
I have a problem with moving a file from "Dowloads" folder to SD card. I have an app that can read files from SD card only (there's no other option) and I'm unable to read the backup data because they're in the other folder. Is there any application I could use to move the file?
Solved! Go to Solution.
It'll be easier to help you if you tell us what are the apps that you are using.
you can try with Astro File Manager.
I used Astro to move the files. Thanks for help!
