Built in wall mounting bracket
SOLVED
Jachamps
New
Thinking of buying a KDL24W605. Says it has a built in wall bracket and no other wall bracket can be used.
Does this bracket tilt and swivel?
May be the deal breaker as was thinking of putting it on an articulating wall bracket.
Thanks for any info
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
Unfortunately the wall mount bracket is fixed and does not tilt or swivel.
Have a look at the wall mount installation guide anyhow : HERE
I have heard of people mounting the TV on a piece of wood (strong enough to hold the weight), then mounting the wood to a VESA supported wall mount.
3 REPLIES 3
Anonymous
Not applicable
Hi there
methemandus
Explorer
sony kdl-50w656asu wall bracket screws the ones your attach the bracket to the wall with they are not supplied what ones do i get
rhyslewis
New
Unfortunately the TV doesn't even come supplied with the correct bracket 'B' as described in that document, I have had it for five months now and am desperate to mount it on the wall but can't seem to get this message through to either Sony or the retailer, who keep sending me the incorrect bracket set. Very frustrating.
