EU firmware in UK tv
Tarzion
Member
Hi,
Is it OK to install EU firmware on the UK Televisions?
I tried once and it went into the blank screen issue and ended up replacing the TV.
1 REPLY 1
Jonnie1266
Contributor
Hi,
When there is a firmware update available for your television you should expect to read the following information on the Sony Support Site firmware update page as the example below:
 Relevant Products
This information is applicable for the following TV models:
  • KD-65X9005A / X8505A
  • KD-55X9005A / X8505A
  • KDL-65W855A
  • KDL-55W802A / W805A / W807A / W808A / W809A / W905A
  • KDL-50W656A / W685A
  • KDL-47W802A / W805A / W807A / W808A / W809A
  • KDL-46W905A
  • KDL-42W650A / W651A / W653A / W654A / W655A / W656A / W802A / W805A / W807A / W808A / W809A /
  • KDL-40W905A
  • KDL-32W600A / W603A / W605A / W650A / W651A / W653A / W654A / W655A / W656A / W503A
  • KDL-24W605A
About this download
  • Name: PKG4.560EUA
  • Date released: 17/11/2015
  • Do I need to update?: Your firmware may already be up to date, especially if you have a new Bravia TV model.
  • Benefits and improvements:
    • Improves the stability of your TV
  • Restrictions: only for use with TV sold in Europe. Not all models are sold in all countries
I think it is always good practise to read about any firmware update prior to downloading it to your product. When your TV prompts for a software update firstly go to here  Use the search function to find your product then you can read if it is compatible.
Regards
If it ain't broke don't fix it
