Hi
Yesterday I bought the above TV and I am thrilled with it. Great picture and all the usual Sony magic. Initially the HDD Digital Recorder DVD player was connected through a SCART. Today I replaced that with an HDMI cable. Now it seems as soon as I turn the HDD on, I lose the picture on the TV. I am also unable to watch a TV channel on the HDD into the TV. I am yet to try and record something on the HDD but in theory this should not be affected as I have not altered anything on that. Why can't I see a live TV picture on the HDMI channel and why does the main TV picture disappear when I turn the DVD HDD on?
My understanding was that I could use the TV to control the HDD DVD. Whilst the TV remote does control basic functions on the HDD DVD, the TV does not seem to be linked as smoothly as I was expecting.
If anyone can throw some light onto that I would be much obliged as I can't see anything in the user manuals.
Thanks
Hi there
In regards to the no picture issue - Can you explain how you have connected everything up?
You should have:
In regards to the remote control issue - Im a bit confused on what the actual problem is.
What I can suggest is:
Hope that helps
Hi there
Can you test both aerial cables individually? From Wall to TV. Also, have a look at the signal strength and quality, to see if one cable is significantly worse than the other. Now if they both work fine, you could try to use an aerial splitter, to feed each aerial cable to TV and RDR-DC205 individually. Thats how I have mine set up actually.
I dont have your model HDD recorder, I have the SVR-HDT500 one, and have it as follows
Also, see page 87 of the manual : Here
and ensure that Standby Mode is set to : Mode 2
