Homestream not showing up as a sever on KDL-40NX723
SOLVED
neil4768
Explorer
Hi
I have installed Homestream console 2.0 on my Viao and it shows  the TV as a n active device.  However the TV is not finding the Homestream server. I have done the follwoing to no avail.
Reset the router, BT home hub 3
Factory reset the TV
gone through server diagnostics the results are PS media Server Succeeded
        Viao XXXX@XXX.com   Failed
        Vaio XXX1@XXX.com   Failed
but no Homesream.
I am now at a lost as what to do to next?
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
As a suggestion:
  • Give the TV a fixed IP address
  • Ensure that you have selected the correct "profile" in the homestream status tab.
  • In the Homestream console's Status tab - Add the VIAO's network IP address to the "Bound IP address" section.
If that still fails
  • Turn TV off from the wall for 60 seconds and switch on again
  • Reboot Laptop and ensure that Homestream is running once started
Hope that helps.
3 REPLIES 3
Anonymous
Not applicable
Hi there
As a suggestion:
If that still fails
Hope that helps.
neil4768
Explorer
Thank you.
That did the trick, the 2nd option worked so easily should have tried that first!!
Anonymous
Not applicable
Excellent - Im glad it worked for you.  I really should have wrote that second option first, in a Keep It Simple approach :slight_smile:
