How to remove information on the top hand left corner?
abh9abh
I have read suggestions to use the display info button but that button does not seem to work. Is there another way to remove the information on the top hand left corner?
Anonymous
Non applicable
Hi there
The Display button (or i+ ) button on the remote control should clear the information on the screen, sometimes you have to press it multiple times in order for it to cycle through the available options.
If that button doesnt work on your remote control for any reason, there 'might' be a setting on the TV - but without knowing which model TV you have, its hard to advise further.
