"No Signal"
nkvjm85
New
"No Signal"
Hi I am using harman/kardon blue Ray DVD player with my Sony Bravia. I receive the above message when I use the player. All my cord connections are right. I know it's something very simple that I missed. Could somebody help me?.. Thank you.
2 REPLIES 2
Anonymous
Not applicable
Hi there
The "No Signal" message indicates a problem with the connection between the TV and the Bluray Player.  Try the following:
  1. Ensure that you have selected the corrected input source.  (ie select HDMI 1 on the TV if bluray player is connected to HDMI 1)
  2. Disconnect the TV and Bluray Player from the power point on the wall.  Disconnect the HDMI cable.  Connect the power again and switch on for 60 seconds or more.  Turn off again and disconnect power plugs from the wall again.  Reconnect the HDMI cable and then plug in the power.  Switch everything on and select the right input source and test.
  3. Replace the HDMI cable (or test with one that you know works)
  4. Perform a hard factory reset of the bluray player (consult bluray player manual for this) as it "could" be picking up a wrong video signal.
Hope that helps
bitisho
New
