Solved! Go to Solution.
since you pass the audio from bluray directly to the soundbar, if you just select the output from tv to the internal speaker leaving all the other setting as-is it should work (output from TV to internal speaker and audio from BD through soundbar. If not the only option that surely work is to manually turn off the soundbar whenever you don't want to use it....
