slow EPG on KDL-32W705B
SOLVED
bigredbus2
Member
We have just bought a new TV replacing our 8 year old Sony. When we first got the KDL-32W705B, the Freeview EPG was quite fast, now it has slowed down as to be unuseable. I thought it might be that we have a media server attached and that the TV was polling all the devices but even with this off, it is slow. Any ideas out there ?
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
This is one of the questions that is hard to determine if its "normal" or a problem.  How does one define/explain fast or slow things are in text on a forum.
I can only suggest that you go into the retailer you have purchased or another retailer and see the speed of the EPG on a demo model.  If its the same, then its normal, if there is a noticable difference, try doing a factory reset of the TV (just in-case) and if not, get the TV exchanged.
4 REPLIES 4
Anonymous
Not applicable
Hi there
bigredbus2
Member
Thanks, I'll try that first...
bigredbus2
Member
A full system reset fixed the problem. Hmmm, looks like I'll have to keep an eye on these rogue processes 🙂
Sion
Anonymous
Not applicable
Brilliant - Im glad its now working.  Thanks for posting back.
