I have the current default of 1x4GB@665Mhz and a spare slot. What are my upgrade options (frequency, size et.)
Thanks.
Solved! Go to Solution.
Hi kriptikchicken,
According to the Sony SVF1521P2EB specifications your vaio has 1 slot with 4GB of RAM installed & supports a maximum of 8GB. The RAM in your Vaio is a PC3-12800 NON ECC So-DIMM module..
Crucial.com's memory advisor, a forum favourite supplier, states your Vaio can support a maximum of 12GB & recommends the following compatible upgrade
If you want to check this you can also download & run there System Scanner tool
However it would have to be your choice if you choose to exceed Sony's maximum supported RAM amount..
Sony have a guide on how to Add RAM in the user guide - Available HERE , a copy of which is below..
Hi there
I believe Crucial has a system scanner tool that will inform you of your options. See HERE
Hi kriptikchicken,
Excellent answer, 'Thalamus' - Thanks.
You're welcome kriptikchicken..:smileyhappy:
