it' possible made an upgrade the hd VGN-FE21B ?
i want put a hd the 320 GB
help me
Hi maxdiable.
Any SATA 2.5 inch hard drive will fit as long as it is not thicker than 9.5mm. Some 500GB drives are too thick at 12.5mm but you should be fine with any 320 GB SATA drive.
Lots here at Amazon.co.uk
Fitting is a very quick job on your FE-Series -
tank's
regards
max
