After reinsalling windows xp on my FE11M the s-buttons don't function! What can i do to solve this problem??? Pleas help me! Is there any driver or some other tool which i have to install???
Thank you for your anwser!
Try downloading the Sony Utilites from VAIO Support which you can find HERE
Then put them to your C:/Utilites
yeah, but which one of the utility tools should I install?
There are 13 different items!
i just realised that my other reply did not send i also said to download the driver packages & then get the updates that are available this should put the drivers back in place in turn your keys should become available
Hi hombreos,
From the pre-installed utilities download you need to extract and install the following.
1 Sony Utilities (Installer Folder 1)
2 Sony Shared Library (Installer Folder 2)
3 Vaio Event Service (Installer Folder 5)
Then re-boot.
You may find that you need to repeat this process a couple times before the hotkeys work.
I must be going mad, I thought I had posted the solution to this already, where did my post go..
I must be going mad, I thought I had posted the solution to this already, where did my post go..![]()
Thanks sanity restored..
