I would like to remove and clean my keyboard but can't find a pdf on this anywhere. Can anyone help with this?
The sony helpline wasn't helpful and just said "I advise against this" and "I cant point you in the right direction"
Hi basshowesy,
I don't know how to remove the keyboard to clean it but i do know there are products available to clean them: pressured air cans which remove alot of dirt
Sorry i can't help with the removing issue, Mark.
This should help you, its a PDF disassembley guide for the Vaio AR series, as far as i`m aware the majority of AR series laptops use the same chassis, its just the hardware that changed when they brought out a newer model.
http://home.comcast.net/~nw_systems/VGN-AR.pdf
cheers Rob
