Hi all im new here.I have problem with my sony vaio vgc-va1.Tv tuner don't have out ports only in but when i plug my tv antena cable in the tv tuner nothin happens i media center.Can anyone help me to watch tv on it and record channels?I live in Bulgaria.
Hi Amateur and welcome.
Are you using the original Windows XP Media Centre Edition?
Have a look at your User Guide Page 33 to see if anything there helps.
ftp://ftp.vaio-link.com/pub/manuals/Desktops/VA1/VA1_H_EN.pdf
Are your TV Broadcasts Analogue (UHF) or Digital (DVB)? Like the rest of Europe, I expect you are transfering to Digital. Have you tried running Media Centre Setup to choose your country and search for TV Channels? I don't think your Vaio is capable of receiving digital broadcasts without a set-top-box.
Hi Blencogo,i tried from Windows Media Center Edition but when i try to set up the signal it wants Contry Code.I don't have the code.Im usin only cable tv,unplug from tf and plug in PC-TV Tuner.
Hi again,i plugged cable in the tv and then from tv out to pc in 3-3 red,white and yellow ok what am i watchin on tv it appears in fly2000tv i record video with bad quality and no sound?Any ideas to repair it?
You would normally connect the co-axial cable to the VHF/UHF ariel socket and run WMC Cable Setup. If you have a Cable Box, you need an IR Blaster.
Make sure you have your Country Settings set to Bulgaria in Control Panel -> Regional and Language Settings.
On the start screen, scroll to Tasks -> settings -> TV -> Set Up TV Signal.
http://windows.microsoft.com/en-GB/windows-vista/Set-up-a-TV-signal-in-Windows-Media-Center
Ok i didnt know the thing with the regional and language options.I'll try tomorrow.And after that i will messege here.
Ok i changed the regional and language settings.When i entered my postal code in media center it seems that my Country its not sported only USA and Canadian...no idea what to do...
