INZONE H7/H9 equalizer for PS5
profile.country.NL.title
Shrinkii
Hi sony,
I was wondering if there was an option to change the equalizer of the INZONE headsets on PS5. The sony pulse 3D has this feature, where you can can change the equalizer en make different profiles.
Are there any plans to make these features available for the INZONE line?
With kind regards
Elodin
Hey, for now you can only change the headset's equalizer settings by using the Inzone Hub on your PC from this link. The newly set equalizer settings will only be available and set for when you're using the headset on your PC but it wouldn't transfer to your PS5. I hope this helps.
pabagin
No it doesn't help.
Hi Sony, Why there is no EQ on the PS5 console? I bought Inzone H7 and it is frustrating that you have this option for cheaper models and competitors. You advertise it for PS5, the design matches perfectly PS5 and the app EQ HUB is best for .... PC and settings don't transfer to PS5 well done PS.
When you will change it?
