Hello.I notice that when tap three times during playback i go to the beginning of the current song.For go to the beginning of the previous song, should clik first pause and then tap 3 times.Is that normal?If i remember correctly with my other earbuds WF1000XM4 (or SP800 , i have both of them) when tap 3 times during playback (without pause) directly i am going to the beginning of the previous track.So what it happens?Is there any issue or SONY make changes about how triple tap works on WF1000XM5?
@vasilisnik Make sure that you tap the touch sensor 3 times quickly and leave about 0.3 seconds between taps. You also can reset the earbuds if it didn't work.
