Equaliser Ui bug on marshmallow
SOLVED
francism
Visitor
Is there an update for the music player? the ui on the equaliser is messed up. I tried rebooting and cleaning the memory of the music app. Equalizer ui
1 ACCEPTED SOLUTION
Accepted Solutions
francism
Visitor
Hi Guys! System update 23.5.A. 1.291 fixed the bug on equaliser's UI. Thanks @uliwooly
11 REPLIES 11
Uliwooly
@francism
Could you elaboarte a bit more ?
francism
Visitor
The fader on the clear bass is not alligned. Please see screenshot inserted.Screenshot_20160503-082225.png
Uliwooly
@francism
I can't see them until they are approved by a moderator.
francism
Visitor
@uliwooly, hi! I tried repairing it via computer thru this xperia companion app. It did not worked at all. I'll elaborate the bug the best that i can. On the equaliser there are 6 with faders. 5 is on vertical and 1 is on horizontal and that's the clear bass. And each fader has level markings. But on my equaliser, the clear bass fader is separated on the bar on portrait mode. Fader adjuster is on top and the bar is at the buttom. Just like removing a train on it's track.. One thing more, the remaining 5 faders was move on the left.. Picture it just like inserting another fader leaving a space on the right side.
SMRTLim
Visitor
I've noticed that my Z3TC, also running Android M, has the same bug as you.
Uliwooly
@francism @SMRTLim
I'll escalate this
Lord_viridis
Does it line up if rotated?
francism
Visitor
Yes it does line up when rotated to landscape mood @uliwooly
francism
Visitor
Sorry for that typo error. Mood-mode
