отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Sony Xperia Tablet Z - Only Charging From USB Cable When Connected to PC
twazzo684
Исследователь
Since yesterday evening, my Sony Xperia Tablet Z stopped charging through a USB cable connected to a plug in charger and now only charges on trickle charge via USB cable plugged into one of my PC USB sockets. i have tried two USB cables, in two different plug in chargers and both cables will only charge the tablet, when connected to my PC
Does anyone have any idea why this is the happening? I have never had this problem occur, previously. Thanks for any suggestions
1 ОТВЕТ 1
profile.country.PH.title
MarlonUk1
did you try to check if there a lose fit on the port of the charger and the phone? this seems to be a hardware problem, try to have your device checked at your local service center,http://support.sonymobile.com/global-en/contactUs/
