could you try to replicate the steps ? this time while on safe mode? i will try to replicate this on my device to see if this is really indeed a bug.
Hi @dmitryperets, sorry to hear that you are experiencing this; but I would like to forward it internally. Could you help me out with some more information?
If you could compile the following and send it to me in PM, I would really appreciate it!
Phone model:
Version (Settings > About phone > Version):
Clock version (Settings > Apps > Clock):
IMEI (Settings > About phone > Status > IMEI information):
How to recreate it (just as you did in your previous post):
In addition, could you please create a bug report after the behaviour occurs? In order to do so, start by enabling the developer mode by going to Settings > About phone, tap the version number until it says that you're a developer. Once that's done, go to Settings > Developer settings and turn them on in the top right > Enable USB Debugging and set the "Logger buffer sizes" to 4M. Now set up the alarm and Do not disturb modes in order to recreate the behaviour, and as soon as it's done (when the alarm goes off but DND isn't deactivated) go to Settings > Developer options > Take bug report > Full report > Report. Now wait a short while in order to let the bug report compile, once it's done you'll see a notification in the top left > Tap it and choose to share the report.
Include the bug report with the other information I mentioned above and send it to me in a PM here on the forum, I'll make sure to forward it internally for investigation!
Thanks! Sent you PM.
Saw your PM, thank you so much for being so helpful - I really appreciate it!
Any update on this issue? I'm new to Android and would love to use this feature. My issue is exactly as the OP described: I set DND to end at 9:00 AM but wish to end it early on days with recurring alarms. I can set up multiple DND rules but this feature is perfect if it can be repaired.
We are experiencing this exact issue on our Xperia XA handsets. Is there any update on a fix??
I think that you should post at the XA1 part of the forum, also, use the search bar, there might be other posts on the same topic
