Bluetooth problem after update to lollipop
Goral08
Visitor
Hi,
I've recently updated my 6503 to Lollipop.
Everything went smoothly and is working fine, except 2 issues - one solved, second NOT.
FIRST (solved) - phone after update waked up and logged to 2G network, with no data transmission (despite it was turned ON). What was strange - my operator's network appeared in 'available network list' as separate 3 NETWORKS ( 2g, 3g and LTE) Slightly_smiling_Face Switching manually to LTE solved it - now phone is switching between technologies automatically, data transmission is working fine.
SECOND AND NOT SOLVED: I'm using the hands-free system built in my car ( mitsubishi lancer, 2008 ) . After update, phone failed to establish connection with it, even hands-free system remained as 'associated device'. OK ... I erased hands-free system from phone, as well as phone from car's memory. Paired devices again - starting procedure from car's side. Nothing better. Erased and paired starting from phone side. Nothing better.
What I've  observed more: phone after try to establish connection , phone in eye blink looses it. On list of available services of hands-free system (in phone menu ofc) , only 'phone sound' appears, while -as I remember but i'm not sure- before update more (2 or 3) services were detected .
 PLEASE HEEELP ! Slightly_smiling_Face
23 REPLIES 23
Saive_nasheer
Visitor
Same problem here
@Goral08
Sony Xperia z1
Mrmas
Visitor
I have the same problem with the difference being that if I put the phone on top of the place where the car bt is everything works fine but if I move the phone further away (keeping it in my pocket) it connects and disconnects all the time. Same thing with my headset. So my conclusion is that the bt coverage is almost none after update....
Leonidus
Visitor
I have the same problem with my D6503 since I upgraded firmware to Lollipop from 4.4.4. Bluetooth pairing is not longer working with Hands free system in my car Mitsubishi Outlander XL 2009Y. I tried different things to pair the phone like cleaning of all paired phones in the Hands free system / cleaning Bluetooth config in the phone, but failed to make it work. At the same time Hands Free system is working properly with other phones like iPhone iOS v.8 and Samsung S4 running Lolipop 5.1. It looks like a well known issue but Sony do not haste to fix it. Did someone get a reply from Sony support?
Jonathon
Visitor
I have another issue. New email notification no longer works with my in-car multimedia system. When I go into the folders on the car's system there are two inboxes, two sent items etc. Not sure if this duplicate folder issue is the cause of the problem.
