hi i have had my mini pro for around 2months now, it is on o2.
i have all the correct mms setting installed and yet i still can not send picture messages.
i can recieve them fine..but CANT NOT SEND THEM.
WHY,
am actually debating about getting rid of this phone as i have tried everything and yet nothing works
ANY IDEAS? much appricated
I had a similar problem with the W395 and it was fixed by a master reset.However, there is no update service for the W395, an option which you have for the xperia.
My check list would be....
Contact O2 to ensure settings are OK. (Tmobile will send a text with the correct settings on - don't know if O2 will do the same)
Try a third party app, maybe Handcent SMS free from the market and see if this does the trick.
If all else fails try a repair/reset via Sony Ericsson Update Service or via PC Companion.
If that doesn't solve it then send it back for a repair via O2 or your retailer.
It must be very frustrating, so I hope you get sorted.
hi thanks for the advice
i have the correct settings,
i have also tried a seconder app
i went to my local 02 shop this morning and the have told me to try a master reset and if that fails then it needs go for repair
Did you try this? settings>Wireless controls>mobile networks>access point names and than MMS settings. try out this and wright here if it works
Ya I have been having the same issues. I have a c905 and it's brand new and can't connect to internet or get picture msg's. I called SOny Ericsson & At&t and none of them will do anything to help, it's absolutly retarded and I have no clue what to do. Any answers from anywhere would help
try what i type up in posts. may it's not same as in c905 as in x10 but you may understand something.
I had the same problem have to do it manually 02 dont send the settings for some reason.
http://mobileguide.o2.co.uk/devices/device.jsp?deviceId=628&tab=8&step=2&settingId=3075
