Whenever i put the phone (Z3+) on charge (Phone switched Off) it restarts on its own when the powers goes off and comes again.
The phone also starts when i firstly power off the switch on the board and unplug the socket than unplug the usb cable from the phone.
It doesnt starts if i first unplug the usb cable.
this doesnt happened with my earlier phones.
Is every one using z3+ facing the same or Not.
No i am not talking about the large battery icon, the phone boots fully.
with any charger same results. safe mode...????
the phone is switched off while charging and it shows large battery icon while charging which is normal but when i power off the swtich from the electric board and than unplug the usb cable from the phone its boots up....
why does it boots up it should remian swtiched off until i boot it from the phone's power button.....
@mukeshkumarmutha If you connect your phone to a charger and the phone switched off by itself then i believe its not normal. I asked you to check in safe mode just to be sure no 3rd party application is causing the issue.
If the problem is still there then perform a software repair from computer. Note that this will erase all the data on internal storage so its wise to take backups.
Sorry I misunderstood, though I can't rectify this as I don't own Z3+, may be someone here who have Z3+ and check whether same thing happen in their device. If it is intentional then you can't do anything, but if it's not then you can always go to your local service centre and ask them to inspect your device.
