SONY !! We need an update for Cairo timezone !!
m3lm
Visitor
Hi there .
We need an update for Cairo timezone ..
Because there is no upcoming daylight saving time .
So my phone shows that Cairo is GMT+03:00
And now it should be GMT+02:00 after we cancelled the daylight saving time or as we call it "summer time"
So what should i do ?? My mobile gaves me an incorrect time !!
Please tell me how to update my phone to work with the new time in Cairo .
Im waiting for the solution ..Thanks .
8 REPLIES 8
profile.country.US.title
Qatrium
I can't see a Daylight saving option on my phone, and also Cairo should be GMT +2 by default, then add 1 hour for Daylight saving.
To solve your problem, you'll need to set your time and date manually.
Meanwhile, contact Sony directly to leave this feedback:
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
m3lm
Visitor
I don't want to set it manually ..
i already made this but it makes time from apps not accurable like facebook app it always shows late time (+01:00 Above the real time)
When i made it manually i can't see if the correct time my friends pots their statuses and also i can't see if the person is offline xx minutes ago ..
Manual time is no good at all
We need an update to set the automatic time zone to can use the accurate time with the apps who uses accurate time (per minute posting)..
MajorxNova
Visitor
+1 we need to change this settings there is no more daylight system in Cairo !!
medo_h_e
Visitor
Same problem here
Mamba89
Visitor
Same here
BoodyGabr
Visitor
Same Problem Here
There is no longer Daylight saving time in Egypt
Nisstr
Visitor
Same problem here
Michy_Spiky
Visitor
Disable automatic time zone and select any time zone GMT +2 ... The problem will solve
