Display oversaturates, contrast, gamma
Gaukh
Hello.
The Display in the sunlight brightens itself too much up which makes it look very ugly. If I cover the sensor on the right next to the top speaker it gets natural again. I can not show a picture because it would start looking normal again in darker areas, so this is pure displays fault in connection with the sensor. Texts start to get contures.
Especially in "Discord" which is an app.
Do you claim to have the same Problem? Help!
profile.country.PL.title
najodleglejszy
it's a feature called Assertive Display that changes contrast in order to improve visibility in strong sunlight
https://www.qualcomm.com/news/onq/2015/02/20/assertive-display-power-efficient-technology-thats-easy...
9 RÉPONSES 9
najodleglejszy
Gaukh
Wow cannot even be disabled.
najodleglejszy
I think the only way to disable it is to root the phone and change some line in build.prop file. still, I find that it really makes display more readable in direct sunlight.
profile.country.US.title
Qatrium
@Gaukh
Not sure about this but, if you disable the "Adaptive brightness" option in Settings -> Display, will it help?
Gaukh
No. The first reply is right. That Qualcomm technology is bad. I mean it is good but very annoying and ugly.
azzido
Passionné
For me it is a good option to boost the contrast, to be honest I wuld liket o have this option to turn it on also when there is no bright light.
If you dig into the details you will see the screen of XZ Premium is not that bright and contrast is rather low. Functionality you are describing is helpful for me, but I acknowledge not everyone likes it.
the_brad
You could try activity launcher from playstore, then create a link on your launcher for 'SVI Settings', launch that, uncheck the option, check again in sunlight.
You're welcome Slightly_smiling_Face
Gaukh
I highly doubt it will help since it really is Qualcomms "Assertive Display" causing it in sunlight.
