I got my new xz and upon using the charger and another qualcomm certified 3.0 fast charger, the mobile is not charging fast even the message is only charging
Solved! Go to Solution.
The message will not say fast charing like other manufacturers phones. SONY should make this fixed in software update ( please )
But if you have a proper SONY UCH12W it will fast charge ( I know because I have one )
I hope to be considered in the next update
at what level are you charging the device.? if you are charging it from 0-80%?.. it might say fast charging but remember from 80% onwards the charger will slow down .
also try to use stock or pre installed themes
you can also time your charging when you are safe mode
