Why can I not share my data connection thru Bluetooth and hotspot. It seems like 1 device is only allowed to use internet. Even if the other devices are connected once I start using data the other devices gets disconnected automatically.
Hi @Keeeeeeeeeee, let me see if I can help out here.
If you want to share your internet connection from your phone to multiple devices at the same time, I would suggest that you use WiFi-tethering instead of Bluetooth tethering. While using WiFi-tethering ou can share your device's data connection with up to ten other devices at once. To use your device as a portable Wi-Fi hotspot, follow the steps below.
Let me know if that helped!
