Xperia XZ1 Compact
Juan911
Visitor
Xperia XZ1 Compact
Amigos me gustaría me ayudarana con lo siguiente, se me llenó la memoria, compre una Microsdxc Samsung Evo select Clase 10 Uhs 3  velocidad de lectura 100mbs Escritura 60 mbs,  y le puse almacenamiento compartido para utilizarla y voy a descargar una aplicacíon en el Ap Store y me aparece memoria insuficiente que pueod hacer ahí??
Friends I would like to help me with the following, my memory was full, buy a Microsdxc Samsung Evo select Class 10 Uhs 3 reading speed 100mbs Writing 60 mbs, and I put shared storage to use it and I will download an application in the Ap Store and I see insufficient memory that I can do there?
gt
2 REPLIES 2
SlowLifeAser
New
First try to clear your apps cache  and for the apps that are possible, move their data to microSD.
You have to keep in mind that not all apps are possible to move in microSD. Also put your phone to store photos and videos on microSD. And if you have music on internal memory. Try to move that one to microSD too.
Jonas
Master
Hi @Juan91, welcome to our forum!
Your question has been translated to English as this is an International forum.
The Xperia XZ1 Compact does not support moving applications to your SD card, or merging the SD card with the internal storage.
If your internal storage is full and you want to download a new application, you will need to free up memory on the internal storage in order to do so. If you go to Settings > Storage, you will find the option to transfer data to your SD card. This will move photos, videos and other media to the SD card and if you have a lot of them, it will free up storage on the internal storage of your device.
@Tsuki, you are correct that not all applications can be transferred to a SD card, however in the Xperia XZ1 Compact, applications can't be transferred to the SD card at all, as this is not supported by the device.
You can still save data from applications on the SD card if this is supported by the application, for example, offline playlists and so forth! Slightly_smiling_Face
Let me know if that helps!
