Hi,
I've just bought a Xperia Z3 but the LTE Frequency does not seem to work.
I registered the phone on Sonymobile.com, but the software versión changes everytime I enter the site.
For example, yesterday the version of software asociated to my phone was 23.2.A.1.62, today, earlier was 23.1.A.0.726, now the version I see is 23.0.A.2.93.
A friend told me that knowing the version of software asociated to my IMEI I can check if the model is the D6603 or the D6653.
I bought the model D6603 because that is supposed to be the model that works with LTE frecuencies on my country.
The D6653 does not work with LTE on my country.
Can anyone help my to find if my Z3 is D6603 model?
Thanks!
Solved! Go to Solution.
I see.
well thats kinda complicated.
To check the actual hardware then you could hook up your phone with PC via USB cable and open PC Companion and see its model name there.
Or else you could download AnTuTu Benchmark for even confirmation on the specs.
Last but not least try this
Open Dialler App > Press *#*#7378423#*#* > Tap on Service Info > Tap Model Info
See if theres any difference in model names in those three steps.
Just in case,is your phone have unlocked bootloader or/and have root access?
I see.
Hi Ashroft98,
I checked the options you told me and the model is D6603.
The problem now is why it does not work LTE in Argentina. This model should work with that frequency here, I check that before I bought it.
Should I open a new post for that?
About your question, I see that in Rooting Status says Bootloader unlock allowed : Yes.
Thanks again Ashroft98!
and oh i hope you didnt get involved with the massive flood in Argentina
I've already check that with my carrier. This model should work with LTE, but it only takes 3G signal.
I also try a SIM from an other carrier that in an other phone works with LTE, but in my phone does not get the LTE signal, so the problem is in the hardware or in the ROM software, but I don't know what else to check.
I tried that and it shows me a message that there is no software available for this phone
