Solved! Go to Solution.
Hi @E_fox, welcome to our community!
I'm sorry to hear about your phone.
If I understand you correctly, when you turn the screen off and you are in a very dark environment, you can still see some light coming from the screen?
I just tried this one a Xperia Z1 and I can't see any light coming from the screen at all when it's turned off.
As @nolramlb mentioned, this sounds like it's hardware related since you have already performed a software repair.
I would recommend that you get in contact with your Local support team and they will be able to assist you with getting your phone sent in to an authorized service centre.
Let me know how it went!
did you mean the screen timeout? you can adjust it to turn off after a few seconds at settings>display>sleep
otherwise this might mean a hardware problem , since you already performed a software repair using Xperia Companion, try to contact your local service center for check up. Local support
Hi @Jonas,
yes you understand correctly. It really looks that I need to find some local support.
Thanks for your advice.
Have a nice day.
No problem at all.
I wish you the best of luck and likewise!
Let me know if there is anything else I can help you with!
