change resolution on A200 manually
profile.country.en_GB.title
adina.bent
Visitor
I have recently broken the LCD screen on my A200 :slight_frown: and is currently set on a low resolution. I was wondering if there is a way of changing the resolution, without having to use the LCD screen?
1 REPLY 1
blaireau_photo
Visitor
Hello adina.bent - Welcome to the Sony Forums :slight_smile:
Unfortunately, as the resolution is set by an on screen menu there is no other way of changing it that I am aware of. I would advise you to see how much a repair would cost and perhaps the best place to start would be Sony Customer Services. Their contact details are available in this thread:
http://www.sony.co.uk/discussions/message/651957#651957
Having said that, if the camera is out of warranty you could also shop around with some other independent repair centres to see how much they would charge.
Thanks,
Simon
