I have an HVL-F42AM flashgun -- but when I attach it to an alpha 300 DSLR I can't get it to work. Neither manual (both written in that peculiar sony-English) helps. There seems to be no WAY OF SETTING THE a-300 TO RECOGNISE THE FLASHGUN.
profile.country.en_GB.title
bimccan31
Visitor
I  want to set an A-300 DSLR to accept and activate an HVL-f42AM flashgun. Neither manual helps -- any advice?
3 REPLIES 3
profile.country.de_DE.title
cmosse
Contributor
Does that mean that the build in flash pops up instead?
  • Please check the following:
  • flash is turned on and batteries are new
  • flash fires if you press the test button
  • flash is mounted correctly on camera
  • is it possible to mount the flash on another Alpha camea to cross check whether the flash is working OK on other model
  • check if the contacts in the flash shoe of the camera are clean. Clean them if neccessary
Mick2011
New
Hi bimccan, welcome to the Sony Forums :slight_smile:
The flash is fully compatible with the a300, so I'd guess you either have the flash settings wrong or the conact terminals are needing a clean.
Wipe the terminals on both  the camera and the flash unit, and have a play with the TTL settings on the flash, see if that helps.
Mick
Mick2011
New
Sorry, cross-posting with cmosse there :dizzy:
All good sugestions..
It just occurred to me you should try to reset the flash unit before you do anything else.
Mick
