Noices inside the camera !!!
profile.country.sv_SE.title
tiffanymisia
Visitor
I have a problem with my Sony DSRL A100 camera.
It makes a strange noice when I switch it on and I can hear some pretty high pitch sound coming from inside the camera . It works normally otherwise but the noices are alarming . Did  anyone come across something similar ?
2 REPLIES 2
profile.country.en_GB.title
Mick2011
New
Hi, welcome to the Sony Forums :slight_smile:
Has the camera always done this, or is it a recent development?
Some noise is normal, as the camera initiates a sensor cleaning routine as part of its power cycling. It can be disconcerting but a high-pitched sound is emitted when this is carried out.
If you feel it is worse or louder than it used to be, it may be malfunctioning; otherwise if it ain't bust, don't fix it :wink:
Mick
profile.country.de_DE.title
cmosse
Contributor
I would check if the noise is also present when no lens is attached and you turn on the cam.
Did you notice some problems with tha Autofocus?
