Play memories wont allow editing?
iprior
Explorer
I can move pic to editing area...but only functions above the line work...not below??
3 REPLIES 3
jumpsuit
Hi there
What are you trying to edit them on? (Laptop / PC / Phone / Tablet)
Have you tried uninstalling then reinstalling?
Also can you elaborate a bit more when you say "but only funcions above the line work."
Which line?
This is from the Playmemories Help:
Editing Photos
"PlayMemories Home" is loaded with many different functions for editing photos.
1. In Calendar View or Folder View, select the photo that you want to edit.
2. Click [Tools] - [Adjust Pictures], and then select your desired edit function.
3. Follow the on-screen instructions.
4. When you finish editing, save the photo.
Hope this helps.
iprior
Explorer
Hi...thanks...the "line"....when I try to edit...there are 3 or 4 options which I can use...there is a horizontal line below which are many more options which are not "Live"  ian
jumpsuit
Hi again
I've just had a look at my PlayMemories and reached this screen for editing photos:
I can see the options below the line, but can't recreate the problem you're having. :cry:
I assume the file is compatible / undamaged?
I don't have a quick fix for you apart from perhaps trying the uninstall / reinstall I'm afraid.
