MEX-BT3600U
MEX-BT3600U
Hi all,
Recently i have installed this system into my car, but i can't connect my HTC one to it.
I can see that it is not on the compatibility list.
My problem is, that bluetooth won't pair. When i press and hold the BT button for 5 seconds, the logo just lit, and is not flashing.
I've also tried to delete all registered bluetooth devices, but that did not work.
do you know how to make it flash/blink again so i can atleast find this bluetooth device on my phone?
Thanks in advance,
Guus
1 REPLY 1
Anonymous
Not applicable
Hi there
My advice it to turn Bluetooth off from the MEX unit by pressing and holding the [BT] button.  Then you can delete any registered devices.  Then hold the [BT] button again to enter pairing mode.
Another thing you could try is disconnecting the cars battery for a couple of minutes, then reconnecting it again.  This may reset the MEX unit.
Your HTC must be compatible with the following bluetooth profiles in order for it to work:
  • A2DP (Advanced Audio Distribution Profile)
  • AVRCP (Audio Video Remote Control Profile)
  • HFP (Handsfree Profile) 1.5
  • HSP (Headset Profile)
