2015 Bravia Android TV Issues
NickCo1979
Member
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
Risc0n
Contributor
People with the 4K stutter issue, have you tried disabling motion flow and film mode, does this fix the issue? Had a similar issue with Apple TV a few years ago and this fixed it.
hankmarvin107
Member
yep, its not a motion flow caused issue.
chrgray
Member
@Risc0n, just tested by turning off MotionFlow and Film Mode.  Had no effect, still juddering 😞
I suspect it's likely caused by these TVs not being able to cope with the high data-rate of 3840x2160 50P on it's HDMI inputs 😞
chrgray
Member
I see on another thread this statement:
@Quinnicus wrote:
Sony are now concentating on the upcoming Marshmallow update.  Outstanding issues will be addressed via Marshmallow now.
Does that mean ALL outstanding issues, including the 4K juddering problem affecting all 2015/16 TVs?  And what is the release date for Marshmallow - before 13th August?
Anonymous
Not applicable
@chrgray - somehow I just knew that was going to bite me :wink:
I wrote that because it is largely true - however at the time, I was not aware of the BT UHD/Sky Q juddering issues.
What I should have wrote is:
Unless there is a major issue, outstanding problems and issues will likely be addressed within Marshmallow.
Im also not saying that all issues will be fixed immediately either.
ETA on Marshmallow = Unknown.
royabrown
Enthusiast
@UKPiglet wrote:
Unfortunately that won't happen as only one Sony employee is allowed to post in these forums, and he is a German speaker who doesn't often contribute to the English forum.
Yes, Sony haven't really grasped the idea of social media yet. So the steam we generate in this forum just vents through a safety valve, not even blowing a whistle. Whereas it could be driving a piston that would give Sony some momentum to get these damn TVs properly fixed 😞
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
kevinwoods12
Explorer
Is Sky Q now broadcasting in 4K? What are you guys actually watching to see this judder? Has anyone got a UHD bluray player,  does  that exhibit the same judder?
chrgray
Member
This - http://m.youtube.com/watch?v=5-myt8ZoVvY
Only seen when the Sky Q Silver box is set to output 2160p50, and only seen on Sony TVs.
rnbetsy
Member
It's already cost them 2 sales from my lack of a Sony recommendation, and
gained Pana 2..
If the 4K doesn't work on Sky properly soon, mine will be going back to
Currys..
Risc0n
Contributor
Interesting, Sony Account Manager was updated for Android 6 ( Marshmallow ) support today.
