My 43xf8096 android tv is connected to my Humax set-top box where I have two satelite cables plugged in. I am not connected to the freesat tuner that comes with the tv. When I enable Youview in settings I am asked to run a search for digital services and the result is always "no services found" and nothing happens after that. Am I doing something wrong. How do I get it to find digital services?
@joeRab wrote:My 43xf8096 android tv is connected to my Humax set-top box where I have two satelite cables plugged in. I am not connected to the freesat tuner that comes with the tv. When I enable Youview in settings I am asked to run a search for digital services and the result is always "no services found" and nothing happens after that. Am I doing something wrong. How do I get it to find digital services?
YouView works off terrestrial broadcasting, not satellite, so you need a terrestrial aerial connected to the TV to get this.
I don’t see above where you describe anything but satellite connections, so this is probably your problem here.
Thank you royabrown2. problem solved
Hi JoeRob: did you solve your issue by getting a terrestrial aerial & connecting it to your TV?
when you tried to install youview did yours come up with the following when asked if you want to start auto tuning?
Antenna or
cable
