- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
After updating my KD-55X8505C to Marshmallow, EPG seems to work much smoother, but it does not keep the favorite selection but it's reset to All programs if I select for example channel with number or press TV button. Not to mention after turning TV on after shutdown.
Anyone else noted similar behavior?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Yes, its now a known issue, see:
https://community.sony.co.uk/t5/android-tv/android-tv-bugs-and-issues/m-p/2300632#M17000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That's pretty much it. Happens also in other ways when changing channel wrong way but same symptoms. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The issue was introduced with V3.843. Sony did not manage to fix it within 2 months. So V3.865 still suffers from it. It tells you a lot about the care that is put into the TV products. Nobody seems to productively use those TVs over at Sony. Suppose there is one part-time guy, who is doing the development and some quick testing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have an 55XE8505, with Android 7.
It is very annonying, that the channel list always exits from favorites.
My provider gives a hundred channels, many of them are duplicates (SD and HD versions of the same channel), many of them are useless talkshows, I want to watch only 20-25, but everytime I have to select the favorites again...
