Input menu
SOLVED
Fanno112
Explorer
Input menu
Hi is there a way to change the order of  theses inputs or delete some ?? Plz thanks
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.IT.title
rooobb
If you go to the last row, you should found the setting option and there you can for sure set which rows to show and (but I don't remember) you should be able also to change the view order.
2 REPLIES 2
rooobb
Fanno112
Explorer
That’s it , many thanks
