When started from cold (Power off at mains) my KD43XD8305BU goes directly to HDMI1. I do not have a device connected here. How can I change it to start in Digital (TV) or HDMI3/ARC. If I switch off from the remote it will come back as the source at switch off
Hi,
try an Android TV Reboot, press hold the Power/OFF key on remote...
Manolo
Does that reset evrything I have set up?
No, it is only a Reboot not a Reset.
Manolo
Ok. I'll give it a go this evening
Thanks
Mad no difference. I think I will disconnect everything then reconnect one by one and see if it loses the 'memory'
Mine always starts up on the sky HDMI port which I'm very happy about, is it just a case of the TV starting up on the connection it was switched off in, try switching off in digital and see what happens when you restart.
Hi
We are expecting a capability to select any other input as default to go to when it is turned on, since Summer 2015.
Nothing is done yet. Sony has forgot this for normal user TV sets. Gives option to proffessional TV sets but not for us.
Do you remember, first setup, if you selected a set top box in HDMI ?
Are you using an IR blaster?
Not sure now what I selected at start. not using IR Blaster. Will attempt to repeat set up from start this evening
