KD43XD8305BU starts in HDMI1 as opposed to TV
bgma79
Explorer
When started from cold (Power off at mains) my KD43XD8305BU goes directly to HDMI1.  I do not have a device connected here. How can I change it to start in Digital (TV) or HDMI3/ARC. If I switch off from the remote it will come back as the source at switch off
12 REPLIES 12
bgma79
Explorer
Well gone back to basics and to no avail. I guess I just have to live with it until Sony provide an update to the OS.  It's fine as long as I do not power down and just use standby
Thanks all
SpookyZeus
Member
How about going back to basics again, doing a factory reset of everything and go through the setup process without having anything plugged into the HDMI 1 port?
Once the TV is working as should then plug in ans setup your device into HDMI 1, aviod turning on any sony active Sync for now too.
(sorry just re read the OP and think you have nothing plugged into HDMI 1?)
profile.country.GR.title
MiCal1967
Contributor
Hi @bgma79
  • Try Disabling this input and reboot your TV
(Go to Settings - External inputs - Manage inputs - press HDMI1 -> select Hidden. Press and hold power button until TV starts reboot).
  • Did you perform an Initial setup or performed a Storage & reset ?
