Zoom lever stopped working. Lever moves freely but zoom does not function. Camera lens stuck on WA, otherwise working OK. Is it easy to open up and fiddle? Thanks, Paul
Solved! Go to Solution.
Did you get this fixed at all? I am having the same problem.
@damonstuart Have you tried reaching out to the Sony support reps? Most likely, it'll need repair.
Waiting for reply from Sony Support. Thanks.
Will let you know when reply comes.
Contacted Sony who gave this reply and it worked for me.
Resets the product to the default settings. Even if you perform [Setting Reset], the recorded images are retained.
(Setup) → [Setting Reset] → desired setting.
Camera Settings Reset:
Initializes the main shooting settings to the default settings.
Initialize:
Initializes all the settings to the default settings.
Glad to hear it was solved!
Thanks a lot for taking the time to share an update, do mark your last post as the solution so others can find it easily.
- JD
Don't know how to mark it as solved, sorry.
