Sony hx80
rebecca4532
New
Sony hx80
Help I’ve got an hx80 and can’t use the manual settings when I try to alter a value in A. S. or M settings I get a not enabled message an example when I highlight a shutter speed value in orange then arrow right or left it goes to the symbol on the wheel drive or flash and doesn’t change the value of the shutter speed. I’ve had a 90v where you just turned the wheel but this is just a press to change settings bought it s/h as I had my 90 stolen don’t know if I’m doing something wrong or I’ve bought a dud although everything else seems to work ok any help would be appreciated
1 REPLY 1
IamNic
Hello @rebecca4532,
have you tried to factory reset the camera to ensure that there is no setting enabled by accident which prevents any manual setup.
- Nic
