Sony MG Jukebox Software ~ Minidisc MD-JB980
SOLVED
profile.country.en_GB.title
PurpleChimp
Visitor
Minidisc Deck MD-JB980 ~ Does anybody have the Sony MG Jukebox? Can anybody explain the use of the USB slot on the back of this unit? If there is no MG Software available, is there an altrernative software that will adapt itself to this unit? Many thanks, in advance, for your assistance.
Message was edited by: -Cass-
Edited for personal details
1 ACCEPTED SOLUTION
Accepted Solutions
PanikJimma
Visitor
You should be able to connect the deck to your computer using a standard usb cable to the port on the back of the unit. Sonicstage is the software you need and the ultimate edition can be downloaded from this link. http://forums.sonyinsider.com/files/file/95-sonicstage-43-ultimate-edition/http://
If you need any more information or if you have any problems I recommend visiting www.minidisc.org, from which the rest of the MiniDisc forums can also be reached.
Hope this helps.
1 REPLY 1
PanikJimma
Visitor
Hope this helps.
